Arcanedeath
Sorry about the long post..... in advance 🙂
Hiya,
I'm trying to install Fedora Core 3 to setup a MythTV HTPC for my Father and I'm a linux newbie, I've played w/ Knoppix on CD before and installed RH7 waaay back when just to mess with linux but I'm pretty much a Windows Guy so any help you guys could provide would be great 🙂.
In any event here is the setup.
Intel P4 630 3.0ghz
Asus P5AD1 Prem. (I915P chipset w/ ICH6R) Specs from NE
2x 512 MB of Gskill PC3200 cas 2 DDR
1 WD1000JB 100GB HDD on the onboard ITE IT8212F set to ide mode (eg not raid)
1 Seagate 200GB 7200.7 in a removable frame (not in the system when loading linux)
1 Sony 4x dual format DVD burner
Onboard Intel HD audio and Marvel Yukon Gigabit Ethernet.
+ the HDTV card (I forget the model /sigh only works in linux though)
(thats pretty much all the important specs/stuff)
I have a 10GB part. on the WD drive w/ WinXP and the ITE IT8212F, this works fine.
I'm trying to install Fedora Core 3 to the rest of the WD drive and I can't get the linux installer to see the hard drive on the ITE controler (if the seagate drive is hooked up it see's that fine on the single onboard IDE controler along w/ the DVD burner) I've tried using the Ver. 1.45 linux drivers from Here and I can get the ITE driver to show up as a raid driver and attempt to load it but FC3 doesn't rec. it as being in the system and only detects the onboard IDE and SATA controlers but not the ITE one.
Does anyone know a way I can get FC3 to rec. my onboard IDE / raid controler properly? (I'm not sure if I even have the right driver but that one from ITE's site was all I could find for linux, but it might be for the stand alone card and not work for an onboard setup) Also as a note I was using the Red Hat 9 driver supplied in the download as thats the highest one listed in the package.
Any Help would be greatly appricated, so far I can't even get the HTPC off the ground Knopmyth was the orginal distro install I tried and it was even more of a disaster.
Hiya,
Intel P4 630 3.0ghz
