hello,
i've had this same problem happen a few months back - i think close to 5 months ago. when i start up my computer, it boots, shows the RAM test, then displays the message "Detecting IDE drives..." (usually, the drives are detected immediately within 5 seconds or less...) and then the computer stalls for about 2 minutes. then it shows the summary of drives - it lists only my primary master drive. i have 2 hard drives on the primary ide channel, though. it won't detect the primary slave drive.
so i unplugged the ide cable, booted up, and of course, my computer didn't detect anything. i plugged in only the primary master and it detected it... after the 2 minute stall. i unplugged that, then plugged in only the primary slave. my computer didn't detect the drive but it didn't stall either.
when i try to boot from a floppy, i cannot access either drive, even though my computer detects the primary master drive. my hunch is that it could be a bad cable, or perhaps my mobo is sorta messed up. the last time i had this problem, i replaced the ide cable and my computer began to work perfectly again. my friend suggested that i try hooking up my drives on the secondary ide channel. i'll be trying that. in the meantime, my rig stats are as follows:
soyo SY-k7vta-b
duron 900 MHz
128 MB pc133 Corsair RAM
256 MB pc133 Crucial RAM
Western Digital 6.x GB (unsure of exact size... i think this is the Caviar series.) - primary
Seagate 9.1 GB - secondary
thanks for any help in advance.
soyo SY-k7vta-b
duron 900 MHz
