- Sep 13, 2003
- 93
- 0
- 0
Hey guys.
I'm trying to fix a Dell Inspiron 600m laptop's power plug by desoldering the old broken plug and replacing it with a new power plug.
The problem is: I was successful in desoldering 10 out of 11 holes of the old plug, and removed the plug, but it appears that a piece of metal is lodged inside the last hole.
Here's a picture of the power plug: http://carlodm.com/eBay/J20_full.jpg
The "piece of metal" is one of the white protruding metals sticking in the picture I just shown you.
The hole is small (about 1 mm in diameter), but the metal is lodged in there that I can't seem to desolder it. I am fairly new in desoldering so any tips is useful.
I use a Weller Soldering Iron (Conical Tip), a RadioShack Desoldering Iron, and RadioShack desoldering Wick.
Is that white metal part of the power plug even necessary? I'm thinking the gold metal plugs are the ones that are important.
Thanks
Thanks
