- Feb 24, 2002
- 176
- 0
- 71
I have a Canon MP640 printer. It has wireless capability, but I've been unable to connect it wirelessly to my Netgear WNDR4500 (N900) router. Any ideas?
have you installed a print driver on the PC you want to print from?
I have the same printer. So you will have to go into the menu and enable the wireless portion of the printer.
Device Settings > LAN settings > change wireless/wired. (set wireless as active). Then you'll go to Wireless LAN settings and choose between WPS or WCN setting. I do the WPS, then choose the push button method, or the PIN method. PIN works well for me since it's displayed by my router.
Hollar if you get hung up
I couldn't get that to work. But I did get it once I figured out I had to enter the printer's IP address when I was searching for the printer.
