Guys, do you know any MB model suited for i5 4460 (or i7 4770 - preferably this one) that:
1) Don't need to update the BIOS to support the CPU - LGA 1150;
2) Has PCI-Express 3.0;
3) 32 GB/RAM;
4) Cool set of features;
5) Not too small;
A few comments:
2) I don't know how PCI-E 3.0 works but it seems most video cards are PCI-E 3.0 nowadays. Cheaper MBs for i5/i7 don't have PCI-E 3.0.
For example, let's say I get the GTX 650 or the GTX 750 Ti. If my MB doesn't have PCI-E 3.0 what will happen? Should I get a MB with PCI-E 3.0 or that is not absolutelly necessary?
5) Perhaps a real possibility if the MB is cheap. Some MBs are too small and when you install a video card it takes space left for other things. For example, in the past I had a MB called ABIT IP35 PRO used for the Q9450 and also the 8800 GTS 512 MB / Blackmagic Intensity Pro, both using the PCI-E.
When the ABIT broke I purchased the DG41TY from Intel. I could not use both the 8800/Blackmagic and I believe not even the 8800 could fit in this MB.
Recently I found this model for i5/i7, however it's a little expensive for me. It can be bought, but I need your opinion if it's the right model or if I may choose a cheaper one, and if so, which one?
- ASUS Z97M-PLUS
http://www.newegg.com/Product/Produc...82E16813132130
I am willing to get another one if this isn't the best (or the only best) choice and the conditions I talked about are met.
Please comment, thanks.
P.S.
By features, I mean:
A MB that is not too deprived of features you can use. As in "if I have to choose between A and B, I will get B because it has two more ports or things I could use, and B costs the same as A, so...".
I can't tell the max budget since it's not in US$. The max budget may be what the ASUS Z97M-PLUS costs.
3) 32 GB/RAM;
5) Not too small;
A few comments:
- ASUS Z97M-PLUS
P.S.
