1sikbITCH
Ok my wife's system- System A- Asus A7V, T-Bird 1Ghz, 512megs Cas2 Crucial Memory
Starting with a Voodoo 3
My system- SystemB- A-Open mobo, P3 800, 512megs Cas2 Crucial memory
Starting with a Kyro II
Tried putting the Kyro 2 in System A first. Uninstalled and deleted all Voodoo software. Restarted in VGA mode. Shut down, switched cards. Ran Kyro drivers setup. Got the system to say it installed the drivers, yet on reboot it would not get out of software mode and did not have options to change the video settings (16bit Color, 640X480 only). Device Manager listed Kyro 2 and had a conflict (drivers). Monitor said "Default VGA mode" or something. I reinstalled drivers 5 times, downloaded and ran 5 different sets of drivers from 3 different places, and jumped up and down like an idiot, all to no avail.
Put the Voodoo back in, installed drivers, rebooted, works fine.
System B- Uninstalled and deleted Kyro software. Rebooted. Shut down, changed to Gainward Geforce 2 T1450. Rebooted, ran driver setup. Driver setup cannot complete installation because it cannot find all the driver files. Deleted that set of drivers and downloaded drivers directly from www.nvidia.com. Run new drivers, same thing. Error- some driver files missing. Try a ton of different drivers (including the CD that came with it). Would not install any of them. Put Kyro 2 back in, install drivers, works fine.
I'm pretty sure in the past I have successfully switched cards before without reinstalling windows. What am I doing wrong? Thx.
