i'm trying to extend my 10/100 (10/100 hub) network with some friends who already are connected on a 10/100 network (10/100 switch)
the minimal distance between the 2 networks is about 250-300 meters (900 feet) so utp cable is out of the question;
i was thinking of a wireless solution but :
1.is pretty expensive
2.i dont know if it can handle the distance properly (almost no interference between the network "heads" ..only 2-3 walls)
3.even it can handle the distance,the wireless card works at 600-700 KBytes / sec at its best within few meters distance so at my distance it will be a real bottleneck (both networks are 100 mb)
what its ur oppinion ? what device do you recommend ? (i can put cable between the networks,it isnt a problem ... )
ps😛lease excuse my english
