Problems booting 2nd OS *Help!*
paruhd0x
3,100
Ok I used to have a Dual Boot Win2k on C: and WinME on D: It worked perfectly till I had to format my C: and reinstall Win2k.
Now Win2k Boots fine but I cannot get WinME to boot up because it thinks winME is on C: for some reason. How do I fix this?
paruhd0x
3,100
I'm going to try to edit the boot.ini file and see if this fixes it. I'll let ya all know.
paruhd0x
3,100
That didn't work. I need to know if there is a repair feature on WinME like Win2k has... So I can get WinME booting again..
Wizkid
2,728
Was your "c:" NTFS before and FAT32 now? If so then try using D: in boot.ini for winme, otherwise you can make c: ntfs and then make winme c: in boot.ini and it should work.
