- Dec 13, 2003
- 7,036
- 8
- 81
I just upgraded my computer, and I am having several problems with it. I upraded from an asus p4t-e(850 chipset) with 512mb of pc800 rdram and a 1.6Ghz p4 to an Asus P4R800(ATI 9100 IGP chipset) with 512MB of Kingmax pc3500 DDR and a P4 2.4c(800mhz FSB). The motherboard has integrated video(radeon 9200) with which my first problem comes. All other part are the same(60GB seagate hard drive with winxp pro + SP1, same sound card, same CD-Rom, same case, 350W enermax power supply, ATI Tv wonder VE). When I try to use my tv tuner card with the integrated video, it instantly locks up my computer when I start the software. I read that a hyperthreaded cpu can cause locks up, so I put my 1.6Ghz proccessor back in, and it still instantly locked up. I put the 2.4c back in, and then tried putting my geforce 3 back in. The tv tuner then worked perfectly and didnt' lock up. I then tried a pci video card also, and again no lock up. I tried again with the onboard video, and it instantly locked up again. When it locks up, I have to either turn the computer off and back on, or hit reset, as I can't Ctrl-alt-del. When I hit reset, it gets an error at bootup saying my bios has a checksum error, and it attempts to load a backup. The only time this happens is if I hit reset, after the TV tuner locks up the computer with the integrated graphics. The other problem I am having, seems related to the IDE interface possibly. The computer is very slow to react when I try to open any programs, or do much of anything with it. It takes 15-20 seconds before I get any reaction after double clicking an icon, open a text file, or anything else. This happens when using either the integrated video, or the the PCI or Geforce 3 video cards. I still have time to RMA the motherboard, but I am hoping something else could be causing these problems, so I am open to suggestion. P.S. I have already updated all of my drivers to make sure I have the most recent ones. There are no BIOS updates for this motherboard yet, but hopefuly soon, as that may could fix some of these problems.
