Problems after overclocking E5200 on stock cooler
rohitshakti
44
Hi friends,
I am a new member of this forum and am also new in overclocking. I recently bought a new pc with the following configration:
E5200
G31 S2l
2GB Kingston 800 mhz
Bijli cabinet with default 450w Zebtronics smps
500 GB HDD Seagate
15" CRT monitor (OLD)
LG DVD writer
I overclocked it on stock cooler and am running it at 3.05 ghz (10x multiplyer with 305 fsb) with normal temp. at 42C and max at 62C on full 100% utilization tested with Orthos and Everest.
My problem is sometimes after normal running of 1-2 days, my system automatically goes back to 200 X 10x = 2.00 ghz.
Pls tell what could be the problem and how to correct it?
http://www.imgx.org/view/full/36783_3wydr]
[/url]
http://www.imgx.org/view/full/36784_1o1wg]
[/url]
http://www.imgx.org/view/full/36980_upfub]
[/url]
http://www.imgx.org/view/full/37242_wcq3h]
[/url]
http://www.imgx.org/view/full/37243_cyekz]
[/url]
http://www.imgx.org/view/full/37244_rywba]
[/url]
http://www.imgx.org/view/full/37245_vffld]
[/url]
http://www.imgx.org/view/full/37246_ej6ck]
[/url]
http://www.imgx.org/view/full/37247_up9vr]
[/url]
brandonwh64
1,543
might be a Vdroop problem what volts did you set it at? ive got a XFX 680I LT SLI mobo and i got it safely to 3.45GHZ and a 1200MHZ FSB at 1.5V but if i go any higher the comp will lock at random times due to voltage drops
VirtualLarry
56,587
10,225
You shouldn't need 1.5V to reach 3.45Ghz. That's dangerous to your CPU.
Triton67
59
If it's a Gigabyte motherboard, be sure to remove USB gadgets before rebooting.
There is an option in BIOS to mimimize risk you're experiencing: disable USB Legacy. Still, my Gigabyte P35 DS3R sometimes reverts to stock FSB, leaving vcore, multiplier etc as they were.
Sometimes your settings in BIOS aren't saved after changes; turn off PC, power off PSU and take out the PSU power cord for a few mins - always helped me (and many other P35 owners)
