Hi everybody
Sorry for the long first message. However, I wanted to make sure that I provide the full info regarding what has happened.
Last week I decided to majorly upgrade my PC (which I originally built 4-5 years ago). So, now I have:
New components
1. i5-4670k
2. gigabyte H87M-D3H mobo
3. SANDISK SDD 128GB for Windows installation
4. 2 x 4GB ddr3
5. A basic LG DVD-ROM
I reused -
6. a SATA WD HDD (I think it was WD Blue)
7. Cooler Master eXtreme 650w atx
8. GeForce 9800gt GPU
I installed and activated Windows 8 Pro on my Sandisk SSD. Installed all the drivers that came with the mobo.
The problems appeared after a couple of days of the PC working well, in the following order:
1. First, I receive a message that "SATA available disk: Removed" and my second drive - WD HDD - disappeared from My Computer. Once I restarted the PC, it came back.
2. Later that day I was using Photoshop CS6 to edit some of my photos which are on my WD HDD. On first two tries, as I was using one of the plug-ins (Color Efex 4), the PC crashed and restarted. Both times there was a rather long error message - unfortunately the crashes happened too quickly for me to properly read them, but there was something about "memory".
3. On the third try using that PS plug-in, the PC froze. After 5 mins, I forced restarted it. After that, the PC refused to boot at all. It would repeatedly try to boot, make noise for a few mins, and then become silent. Then it would automatically try to start again - and again unsuccessfully. And so forth, until I unplugged PSU. The screen would alternate between being blank on one boot attempt or getting to the motherboard welcoming screen on the next one (i.e. where you choose to enter BIOS, boot, etc).
4. I checked inside the case, and everything was in order and connected.
5. Next day, the PC started normally and worked fine most of the day. However, when I tried to use the Photoshop again, my WD HDD (and possibly DVD-ROM) disconnected and disappeared again . They "reappeared" on restart.
6. I ran SeaTools and WD Diagnose tool for my HDD and both said that the HDD passed the tests (one WD test took 2 hours).
7. Today, I decided to check SATA cables - I changes the cable that connected to HDD and also connected it to other SATA on the motherboard. After that the PC stopped starting and behaved like I described in Point 3 above - i.e. repeatedly trying to boot. I checked all types of SATA connectors/cables combinations without success.
8. I tested individual RAM sticks by alternatively removing one of them and booting the PC. One time, the PC started with one of the sticks. However, it was a one off and then it would not start again.
9. Finally, I gave up, put everything back together (with both RAMs), closed the case, pressed the power button and...PC started.
Irrespective of the PC now working, there is obviously a problem and I do not know when the next crash/disconnect will happen. Do any of you have any ideas regarding what it could be or how to check it?
BTW, the reason I was testing the RAM as per Point 8 was because I remembered how I stupidly tried to force them in when I was putting the PC together (totally forgetting that they can only go one direction). But it appears that they either both work or are both are semi-broken.
Thanks in advance for responses!
New components
1. i5-4670k
4. 2 x 4GB ddr3
I reused -
