Problem worse. Computer freezing instantly after starting.
MikeWasHere
25
I wrote last week about random lock ups from my computer...well, the problem soon got much worse. As soon as I hit the power button, all the lights turn on, the fans starting spinning, the hard drive and cd/dvd drives start spinning, but nothing else happens. The red "working" light just stays lit as soon as it comes on and i get no beeps. The monitor never clicks on.
I've put different ram in the computer that I know works, and the problem persists with no change. I don't see any visible damage to the processor or the motherboard, and have no way to switch out any parts to isolate which one might be the problem. Any ideas as to what could be the problem? I would assume it's either the processor or the motherboard since everything else seems to be working.
LiLithTecH
3,105
Do you have the RAM in Dual Channel mode?
Does the PC boot ok into SAFE MODE?
If so, did you try REMOVING (physically) the Audigy from the System?
Did you 'Disable' the On-Board audio?
