Problem withe the ECS K7S5A Revisited
Aug 21, 2003
56
i'm trying to setup a computer with this ECS K7S5A motherboard. All the parts are in place, including a PCI video card. As i've posted before i'm having trouble booting this sucker up. after the ram check and ide auto detection stuff the boot process just stops. after the afore mentioned memory and ide checks and detection's i get two of these three error messages; "CMOS Settings Wrong," "CMOS Memory Size Wrong," "CMOS Battery Low." Than two options appear below it "F1 to Run SETUP" or " F2 to load default values and continue." But i for some reason i can chose either option, for some reason my keyboard can yeild an input response. Now first off this keyboard does work, i've tried it on other comps, and used other keyboards on this same comp with the same result. I have changed the CMOS Battery, and cleared the CMOS itself, and the problem still presist. I am just asking for any suggestion from any body who can help. If anything i'm seeking confirmation that this can be fixed (and i'm not crazy) or i got stuck with a bad mobo. The ECS website suggestion to update the bios to fix at least the "CMOS Battery Low" problem, but i do not see how this can be done with these circumstances. Anysuggestion, on how to do anything would be much appericated.
