Problem with Wolfenstein - Enemy Territory.
Zero Plasma
Banned
Jun 14, 2004
871
Heres what it said.
ET 2.55 win-x86 May 27 2003
----- FS_Startup -----
Current search path:
C:\MYPROG~1\WOLFEN~2\etmain\pak0.pk3 (3725 files)
C:\MYPROG~1\WOLFEN~2\etmain\mp_bin.pk3 (4 files)
C:\MYPROG~1\WOLFEN~2\etmain\mapmedia.pk3 (10 files)
C:\MYPROG~1\WOLFEN~2\etmain\lights.pk3 (51 files)
C:\MYPROG~1\WOLFEN~2\etmain\common.pk3 (41 files)
C:\MYPROG~1\WOLFEN~2\etmain\astro-skies.pk3 (11 files)
C:\MYPROG~1\WOLFEN~2/etmain
3842 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using desktop display depth of 16
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...using colorsbits of 16
...calling CDS: ok
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Whatsm wrong?
SneakyStuff
4,294
I had the same problem on my OOOOOLD pentium 3 450 MHz with an 8mb RAGE turbo, you need to get the latest drivers for your video card.
