I am attempting to get my brother-inlaws computer working betterand wanted to show him how to use the request remote assistance feature as he lives 90 miles away. When I found his help center will not open. When you click on the link in the start menu there is a brief flash but nothing else. I have also tried the command line helpctr.exe with the same results. I have found that the help files folder C:/windows/pchealth/helpcentr is empty. could this be the problem? and if so how do I install these I do have the install disc but so far have been unable to locate them :frown: I am considering sfc /scannow will this replace the help files? I can usualy get these things figured out but thought I would see if anyone has a suggestion
The system is a P-4 2.4 running XP SP2 with all updates current I have done several spyware and virus scans with no problems found.
Amos
Amos
