-> Problem with W2K <-
Nkcowboy
426
Hey,
I just installed Windows 2000 Pro for the first time (I have WinME before), and I have installed DirectX8.1, the latest display drivers for my Radeon 8500, and all the other necessary drivers. However, I installed "Return to Castle Wolfenstien" and then when I tried to play it I got this:
Wolf 1.0.0 win-x86 Nov 13 2001
----- FS_Startup -----
Current search path:
C:\GAMES\RETURN~1\main\sp_pak2.pk3 (232 files)
C:\GAMES\RETURN~1\main\sp_pak1.pk3 (1342 files)
C:\GAMES\RETURN~1\main\pak0.pk3 (4775 files)
C:\GAMES\RETURN~1/main
6349 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'D:\WINNT\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Basically the problem seems to arise from the OpenGL thingy. Is this a common problem with Win2K? What can I do about this (the copy works fine on my other Win98 PC). Thanks for any help!
Mitzi
3,775
You did get the latest version of the Windows 2000 drivers for your graphics card?
bacillus
14,517
could you post your wolfconfig?
I suspect that it will say something like
seta r_lastValidRenderer "3Dfx Interactive Voodoo(tm)"
seta r_glDriver "gl/openglv3.dll"
