I just purchased a new PC with the following specs
p3 733, ASUS geforce video, 128 RAM (133), Gigabyte 6vxe7+VIA M/B & win98. It seems to run fine until I try to install my old Creative Voodoo 2 card. The system then does the strangest lockup.
When it starts I can not open the start menu, and I cannot right click the mouse on the desktop to bring up screen properties. The system just hangs. I can however get into the control panel from "my computer", the device manager shows no conflicts, but all I can do is reset the computer by control-alt-del (because I cannot access the start menu to select shut down).
Some people have indicated it could be a problem with the VIA chipset motherboard. Anyone else heard of similar problems, or can you offer a suggestion.
Thanks
Thanks
