DeadlyTitan
So, i really need some help here. I got some tutorials from my class which i am supposed to follow and learn a few things but the thing is i cannot access some of them. I can see them on my hdd but when i try to open them it says it cannot find the file. I did checked my friends files and they worked fine, i tried copying them and they did copied but then the same problem. I have no idea what's happening. I gotta say its specific to the HDD, if i store else where like on my other HDD's the files are working, however it ruins my folder structure and i cant live with it, like i just cant copy them to a random drive without proper organisation. I run comodo internet security and did a virus scan and malware scan and nothing appeared. I keep my system relatively clean with no junk installed and not allowing others (friends/relatives) to jam their USB drives into my system, so am sure its not a virus/malware problem.
I did a HDD scan using sea tools and HD tune and both came relatively good with no errors/damaged/bad sectors. however i still have this dreaded problem that i have no idea what to do. I cannot delete them cause it just says file cannot be found, i cannot play them cause well same frigging error. The drive is new, around 6 months old.
I did multiple restarts and well nothing happened. As you can see in the images, i have no idea what's wrong. Help would be really appreciated cause am clueless and lost.
System Config -
System Config -
- i7 8700
- 2x 16 GB Ram (3000 mhz cas 15)
- GTX 1080 ti
- Toshiba 2 TB Drive (new drive) (this is the drive i am trying to store them)
- Seagate 2 TB Drive (new drive)
- Seagate 1 TB Drive (recycled from old PC)
- Samsung 850 evo 512 GB SSD (new drive)
- Samsung 850 evo 256 GB SSD (new drive)
- z370 MSI Board.
- Corsair RMX 750 PSU (new psu)
