- Sep 2, 2004
- 128
- 0
- 0
I just recently build my computer, after finishing the installation everything seemed perfect. Then I turned off the computer and started organizing the numerous cables I have in my desktop, arranged them nicely and moved the computer around. After I connected everything and turned on the power, everything booted correctly except the video card, the monitor just kept blinking as it usually does during boot up. After numerous restarts it worked and I got to windows, only to notice that the background had some strange lines in it. Then a Vpu error appeared on screen. I have tried everything, installing newer drivers, double-checking monitor cables for connection etc. Right now it is working properly after numerous shutdowns, but if I move the computer it just freezes and a vpu error appears. What can be happening?
It is currently connected throw a DVI to VGA adapter to my monitor
System Specs
-3.0 Prescot
-1gb Ram
-Asus p4p800e Deluxe
-400w PSU Thermaltake
System Specs
-3.0 Prescot
-1gb Ram
