Originally posted by: dmcowen674
That is amazing, I have yet to see a CPU fail yet either. I thought I had a cooked Intel CPU last year when the CPU fan died but it turned out to be the actual Motherboard material and traces around the CPU fried and got so brittle that the traces got broken up.
Were you Overclocking it? Maybe it might not run at higher timings anymore (natural silicon decay) and could try backing down a tad?
This box only does file storage, DVD/CD ripping, and SetiQ so I must confess I wasn't paying much attention to it. I only noticed that it had a problem because I tried to check my client status with SetiQ and it didn't respond. I flipped the KVM over to it and found it in the process of a reboot. Then I noticed that it had been rebooting on it's own for a few days.
All at default - CPU, FSB, RAM, PCI, AGP, voltage, etc, etc. Power supply and CPU fans both working fine and intake/exhause 120mm fans operational so I don't think it was heat. It's got 5 HD's, a DVD, and a CD drive along with a Promise RAID card so I thought maybe the PS (True 380?) was overloaded. I disconnected the RAID card and 4 drives and still got BSOD's. Tried using a spare 300W PS and same thing. Even reset the BIOS to default and tried a fresh load of Win2K Server and Win2K3 Server. Both resulted in BSOD or other errors. I hooked the RAID card and drives back up and put the 1.6A out of my 3rd system into this one and it's been solid ever since.
I looked closely at the CPU and there's no burned or dark spots anywhere. All pins look fine. I called Intel and after about 15 minutes of talking to them about the situation they agreed to setup an RMA. I'm still waiting on the number though - something about confirming the CPU was a boxed unit originally. I told him I know it's boxed because I'm holding it in my hand but he had to verify it there. Funny but I keep all of my 'puter hardware boxes - in fact I recently cleaned out the top shelf of my closet because it was full left to right and stacked to the top. I threw away things like a Diamond Monster, Diamond Monster II, Soundblaster 16, and P1 motherboard boxes.
<== Packrat!
