Hi,
I find there is a slight inconvenience with the std::getline function in C++. Here is an example:
#include <iostream>
using std::cin;
using std::cout;
using std::endl;
using std::getline;
#include <string>
using std::string;
int main()
string strTemp;
cout << "Enter a sentence: ";
getline(cin, strTemp);
cout << "\nYou entered: "
<< strTemp << endl;
return 0;
If you run the code above, and hopefully I did not leave anything out, out will find that after you entered a sentence and press Enter, the "cursor" will go to the next line, but the program does not move onto "You have entered: " until you press Enter the second time. In other words, I have had problems with the getline function in term of having to press Enter twice to get it to move onto the next algorithm.
I have tried for example:
getline(cin, strTemp, '\n');
It has the same effect.
Is there a way to get around having to press Enter twice?
Thanks,
Kuphryn
#include <iostream>
using std::cin;
using std::cout;
using std::endl;
using std::getline;
#include <string>
using std::string;
int main()
string strTemp;
<< strTemp << endl;
return 0;
Thanks,
Kuphryn
