- Apr 16, 2005
- 407
- 0
- 71
I recently downloaded the free version of Starsiege: Tribes, which is version 1.8. I have downloaded the patch to 1.11 twice now, and every time I try to open the patch, I get an error message that says.
Can't run 16-bit Windows program
Cannot find file C:\blahblahblah\tribes18to111.exe (or one of its components). Check to ensure the path and filename are correct and that all required libraries are available.
I also have something called wowexec.exe running in the background, which from what I've figured out from the all powerful Interweb, helps 16-bit programs run properly in WinXP. So I have no idea why this patch won't install. Any ideas?
