problem with sound blaster driver installation
DarkKnight
1,197
whenever i try to update the drivers, the installation program gives me an error saying that it cannot detect a sound blaster live installed. BEcause of this, it does not copy the driver files to my harddrive. Is there any way I can get the sound blaster live driver files without using the installation program?
sinisterDei
324
26
Yes, you can get the drivers to your hard drive. There are two ways.
1) Start up the install program, and quickly check your C:\Windows\Temp (if you have 9x) or C:\Documents and Settings\[user]\Local Settings\Temp (for 2k/XP) folder. That is where the SBLive!Ware installer program drops all its files temporarily, and you are free to drag-n-drop them to wherever you want.
2) Find a program called i5comp or i6comp. It is an installshield cab file extractor you can use to manually extract the files from the cab files without running the installer. The programs are a bit rough, mind you, and not for the newbie user, but they do work.
You might be better off, however, figuring out why the installer doesn't show you having a SBLive! card than trying to jury-rig its drivers :)
