- Feb 23, 2005
- 22,902
- 2,360
- 126
First, my setup:
Main PC upstairs connected to an E4200 router then ISP modem. HTPC downstairs with wifi card, and hardwired into a Linksys 310N configured with DD WRT as a bridge.
Everything was working fine before, but I installed a new hard drive and clean install on HTPC of Win 7 Professional. PC upstairs is running Win 7 Ult. My issue is I cant access sharded folders on the main PC upstairs from the HTPC downstairs.
Here's what Ive done.
Deleted Homegroup on both PC's and started over. I also tried setting up the Homegroup on either PC, same problem.
Ive tried sharing without using a Homegroup using THIS method.
Ive tried via the wifi card in the HTPC connecting directly to the E4200 upstairs wirelessly, as well as plugged hardwired into the bridge.
Each time its the same result. When I open up the Homegroup window, I see the shared folders on the main PC upstairs. When I double click one of them, it time out then gives this error:
When I click diagnose, I get Troubleshooting couldnt identify the problem.
I tried sharing the entire drive upstairs then mapping a network drive, and get this:
I double checked permissions on the drive as you can see here:
Ive also triple checked permissions while in the Homegroup...right click folder, share with Homegroup.
Ive tried disabling the firewall and AV on both PC's.
I dont get it! I have full internet access, when I refresh the homegroup page everything shows up, I just cant open it.
Any ideas?
Any ideas?
