przero,
Sometimes we download "FAT" Work Units. It seems to happen more than just randomly on people's 1st WU!
This is how to get rid of a (that) WU and try the next one.
Open SetiDriver and uncheck HIDE PROCESSING. You will probably see a DOS TAB in your tray that is identified as "SETI xx". The "xx" identifies the WU number you are working on.
Now shut down SetiDriver by clicking on the EXIT button located right under the TRANSMIT/STOP TRANSMIT button.
To make sure it is off, do a CTRL-ALT-DELETE and check your Processess Tab. If you see "setiathome-3.03.I386-winnt-cmdline.exe" listed there, click it to highlight it and then click on END PROCESS. Sometimes that executable doesn't shut down when you exit SetiDriver.
Browse to your Seti folder and now delete the "xx" folder.
Now assuming you created a startup shortcut, go to START/PROGRAMS/STARTUP/SETIDRIVER.EXE and restart SetiDriver. Watch it a few minutes ... it should start showing some progress in the bottom bar pretty quickly.
If this fixes the problem, recheck HIDE PROCESSING and click on the SAVE CONFIG button to register your settings.
Let me know if this did the trick.
