problem with seti client
reddem0n
105
I turned that display transmit feature off, but for some reason whenever I run the client it still constantly shows that dos prompt coming up with the transmission status etc, and its really getting annoying. Anyway to stop it?
Wiz
6,459
16
Are "Hide Processing" & "Auto Transmit" & "Use Seti Driver" checked?
Smoke
Distributed Computing Elite Member
Jan 3, 2001
12,650
207
IF you are running Seti-Classic and Seti-Driver:
The DOS DISPLAY will stop appearing after you have gone through your initial batch of downloaded WUs. Just keep the DISPLAY TRANSMIT UNCHECKED. ;) :)
Spacehead
13,067
9,858
Also, always remember to hit the 'Save Config' button after making any changes in SETI Driver.
