I'm building a system for a friend and have everything put together, fired it up, and nothing on the secondary ide channel is recognized. I first thought it may be a problem with the burner (the only thing on the channel) so I tried another drive on it. No go. Then I moved them around, everything on the first channel works fine, still nothing on the second. I switched cables out. Still nothing. I cant think of anything else to try. Could it be a bad motherboard? Is there anything else I can do? Its brand new so I guess I should RMA it? I'm also having problems with the floppy drive reading disks, but at least its recognized. Its giving me a Disk I/O error. Let me know what you think. Thanks!
