An HP DeskJet 660cse printer that I use keeps on grabbing many sheets of paper at a time. This clogs the printer and prevents it from printing properly. I heard of some sort of kit that you could order from HP for this problem, does anyone know anything about this? Thanks
Thanks for the link, I was having problems with that too...it'd grab a few sheets staggered and print lines partway on one, then on the other when the next sheet started...I had to start feeding them manually one at a time!
Take the tray out and clean beneath the roller bar and the roller bar also. I have this printer to and clean it peridically to prevent this from happening.
I also use a portable compressor to blow out dirt and gunk inside the case
