Unable to complete secure transaction
You tried to access the address
https://lavabit.com/, which is currently unavailable. Please make sure that the web address (URL) is correctly spelled and punctuated, then try reloading the page.
Secure connection: fatal error (44)
The certificate has been revoked by its issuer. It is no longer valid. In the worst case it may be used by criminals for fraudulent purposes. The website owner must immediately replace the certificate.
The certificate was revoked because the key associated with the certificate has been compromised, and the certificate cannot be trusted.
Make sure your internet connection is active and check whether other applications that rely on the same connection are working.
Check that the setup of any internet security software is correct and does not interfere with ordinary web browsing.
If you are behind a firewall on a Local Area Network and think this may be causing problems, talk to your systems administrator.
Try pressing the F12 key on your keyboard and disabling proxy servers, unless you know that you are required to use a proxy to connect to the internet. Reload the page.
Need help?
Open the Opera Help.
Go to Opera's online support desk.
