problem with quake 4 on 2005fpw
Jpark
2,906
I tried to edit my config file with this:
seta r_customHeight "1050"
seta r_customWidth "1680"
seta r_fullscreen "1"
seta r_mode "-1"
seta r_aspectRatio "2"
it does nothing in game though. I've searched google and haven't turned up anything that works. Any help is appreciated.
xtknight
12,974
What happens when you type vid_restart in the console after the game starts up? Anything different?
MX2
18,651
You can just open the console with ctrl+alt+~ and run the commands though there, just enter a line at a time:
r_mode "-1"
r_aspectRatio "2"
and to make the changes take effect:
vid_restart
Jpark
2,906
will i had to do this each time i play or can i do a read only on the config file to make it to where it won't change?
Jpark
2,906
Originally posted by: MX2times
Once I did it in the console, I didnt have to do it each time.
will give it a try. thanks for the help.
edit: worked. thanks
nycdude
7,809
I will try this. I think the graphics looks awful on my comp. Have a x800XT PE with 2GB of ram. I must be doing something wrong.
update: settings seem to work
