- Nov 23, 2001
- 6,740
- 156
- 106
I pulled this older plextor out of my laptop that had a failed fan.
I suspect it might have bad sectors so I figured i'd wipe it and update the firmware to see if that fixes the system lockup I noticed.
I tried updating the firmware with the bootable .iso provided by the plextor website, but it failed.
It seems to be trying to download microcode ?
The crucial ssd bootable iso said the same thing, but didn't fail.
What's going on here ?
Does it look like the drive bit the dust ?
Code:
smartctl -a /dev/sde
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.4.16] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Plextor M3/M5/M6 Series SSDs
Device Model: PLEXTOR PX-128M3
Serial Number: 002150101377
LU WWN Device Id: 5 000000 000000000
Firmware Version: 1.00
User Capacity: 128,035,676,160 bytes [128 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS, ATA/ATAPI-7 T13/1532D revision 4a
SATA Version is: SATA 3.0, 6.0 Gb/s
Local Time is: Sat Feb 1 06:05:27 2020 MST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 10) seconds.
capabilities: (0x15) SMART execute Offline immediate.
No Auto Offline data collection support.
Abort Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0002) Does not save SMART data before
entering power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x00) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 10) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x0003 100 100 070 Pre-fail Always - 0
5 Reallocated_Sector_Ct 0x0003 100 100 000 Pre-fail Always - 16384 (0 22)
9 Power_On_Hours 0x0002 100 100 000 Old_age Always - 72348
12 Power_Cycle_Count 0x0002 100 100 000 Old_age Always - 21
178 Used_Rsvd_Blk_Cnt_Chip 0x0003 100 100 000 Pre-fail Always - 88
187 Reported_Uncorrect 0x0002 100 100 000 Old_age Always - 178
192 Power-Off_Retract_Count 0x0003 100 100 000 Pre-fail Always - 22
SMART Error Log Version: 0
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
Selective Self-tests/Logging not supported
