Here's my problem....most of my programs in WinXP are running slow. I know what the problem isn't. I don't have any viruses or spyware. I ran across this problem before and eventually had to reformat; then I found out about the /R with the CHKDSK command that has helped allot, but it looks like the damage is a little too severe this time.
I want to know what's causing this problem and how I can prevent it and then finally how I can fix it if I can't prevent it. I know this is a software problem because like I said this happened to be before in another system which was completely different. Here are my specs: A64 X2 4400+, 2GB DDR 400 RAM, MSI K8N Neo 4 Plat, GeForce 7800 GTX 512, SoundBlaster Live!, WinXP Pro w/SP2. I'm also running ZoneAlarm Pro with Panda Titanium 2006 Antivirus + Spyware. I also use Diskeeper 10. I don't think my firewall and antivirus software matters but there it is anyway. Oh and I have various spyware programs too, Pest Patrol Spybot....etc etc...
Apparently it has to do with file structure damage or CHKDSK /R wouldn't help it. Windows boots just fine but many (not all) programs run extremely slow. Does anyone have any idea what might cause this? Also I've run CHKDSK on both volumes....that is I have two hard drives. One is a 80GB and the other a 250GB. This wouldn't have anything to do with the size of the hard drives would it? I wouldn't think so. I just know I hadn't had this happen until 2005. I do regular maintenance on my PC so I don't understand what it is and what causes it.
The first time this happened, it started after I d/led a large file. I think it was the antivirus wanting to scan it, but even after I deleted it, it's like it permanently affected many other programs. For example, it takes about 1 minute for IE to load. I usually use Firefox, but I occasionally use IE. Anyway what gives? Also it takes about 2 or so for Windows to shut down. It goes to the blue screen before it shuts down and then you see the hard drive light just stay on until it finally shuts down. The HD light stays on too when it's loading programs but takes a long time to load them. It's as if I don't have enough RAM or something...weird. I've streamlined my services too and I have very few TSR's running so I know that's not the problem. Once a program or game has loaded, it runs just fine, it's just the loading part...I don't understand what the problem could be??
