problem with power fan and chassis fan
galaxyboy
24
hi,
i have asus mobo model a7n266 VM
asus pc probe shows that the
"power fan and chassis fan speeds r below threshold limits"
the readings are
cpu fan : 4821 rpm
power fan : 0 rpm
chassis fan :0 rpm
but when i had a look at them both r not idle they r running at some rpm.
where did i go wrong ?
what should i do ?
also pc probe doesnt have any help file .where can i get the help for this probe ?
thanx in advance
bye
dartworth
15,200
10
what kind of fans are they? panaflos only have 2 wires for power...some other fans have a third wire for rpm feedback...
galaxyboy
24
the chassis fan was included in the cabinet ,i didnt buy it seperatly.
where should i connect the rpm wire ?
there is no reference about where to connect these fans on the mobo.
what should i do ?
