Problem With Partitioning
hell911
47
Im trying to partition my 1TB 5400RPM hard disk, but im receiving this error.
these are the results of HD TUNE PRO
this is the result on Crystal Disk Info
Any Help!! THANK YOU!!
Coup27
2,140
Run Chkdsk and see if it finds any errors or corruption. If it does, fix them and try again. If it doesn't, use a different partition tool such as GParted.
mv2devnull
1,516
153
Why the error says: "to shrink"?
Which was run first, the Crystal Disk Info or the HD Tune?
hell911
47
Why partition a 1TB 5400rpm HD?
isn't it a good idea? i just want to make a separate partition for drivers of laptop? :\
what do you mean? that error "to shrink" came from disk management.
also, i ran first HD Tune pro, then crystal disk info.
_Rick_
3,943
69
Partitions, in my opinion, have no reason to be used anymore.
If you want to artificially limit the amount of space available to certain subsets of data, use quotas.
File systems are sufficiently stable, that there's no point in having a backup on a separate partition of the same disk.
There's no reason to split a disk with partitions, as it will only limit your options when one of the partitions runs out of space.
There's really only one reason left, where partitions make any sense:
If you run different operating systems on a PC, with incompatible file systems.
hell911
47
i actually ran the chkdisk like 4 months ago..
before there was 1 damaged block (color red), as you can see in 2nd picture, now there is no damaged block. im guessing it is repaired from chkdisk?
razel
2,337
90
101
4 months is a long time ago. Re-run chkdsk. Chkdsk is different from 'check disk'
Warsam71
287
And are you planning to use it to store videos, pictures and/or large files? If so, I wouldn't partition it as Rick has mentioned.
If it's an old HDD, I suggest buying a new one if you can since 1TB drives are about $50 to $60 now. The amount of time you may spend trying to fix it with chkdsk or any other tools may not be worth the time.
