Problem with OC
exidus
14
Hi guys :)
I'm sort-of-a-newby in this, but I think what's happening is not normal:
My set-up is as stated in the topic:
CPU: C2Q Q9550 (E0)
MB: Gigabyte X38T-DQ6 (bios F7f - supports E0)
RAM: DDR3 8GB /4 DIMMs - 2x(2x2GB) @1800MHz Corsair Dominator CM3X2G1800C8D/
PSU: Hiper 880+
GPU: Gigabyte 3870 512 DDR4
I have also LC on the CPU and GPU. The idle temps rarely exceeds 35C and load temps - 45C
Both memory modules and MB supports X.M.P. @1800.
OK... so ... Everything is working nice, since I don't touch the FSB freq. Default FSB is 333, so the RAM runs @1333 on 8-8-8-20. These are the best timings I could get @1333. I'm thinking DIMMs can do more, but no luck....
Every attempt to rise the FSB leads to re-loading the default CPU/FSB settings in BIOS. I've tried almost everything I saw in forums (slight rising of Core, PCI-E and RAM voltages within the safe margins, disabling load-pipe control and power saving voltage control). Nothing worked.
I don't want to extreme OC the system. My goal is CPU@ 3.2 - 3.4 GHz, FSB@400MHz, ram@1600MHz, if possible...
Soooo... any ideas are welcomed :)
exidus
14
@ BTRY B 529th FA BN
thank you, man :)
Yep, I do have a dd3 1800, but for now i doubt about the point having it, as I can't enjoy even 1600... :(
Nov 26, 2005
15,197
403
With that DDR3 speed you should top out at 450fsb and that will be enough to reach your overclocking goal. 450x8.5(mulit) should bring you to 3825Mhz at those rated timings. I think all you really have to do is leave most everything on auto except for the fsb and raise it accordingly. I've read what you have done and can't understand "so the RAM runs @1333 on 8-8-8-20. These are the best timings I could get @1333" Did you change the timings also? Are you running the memory at the rated voltage?
exidus
14
Original timings for 1333 are 9-9-9-24 @1,5V, but there is an X.M.P. with 6-6-6-18-2T @1,5V for 1350MHz and 8-8-8-24-2T @1,8V for 1800Mhz. Current config: 8-8-8-20-2T @1,5V 1333MHz. I've tried rising only the FSB, with all others on auto.
The system is halting even if I rise it by 1 MHz. My previous processor was Q6600 (FSB @266x4). I had the same problem with it: Original FSB @266 working without a glitch, but no chance of geting it working with other freq.
So the main issue is: Why is it working fine with the original settings @1066 and 1333, but does not overclock at all.
So far I've eliminated following eventual causes:
- temp: Both CPU and chipset are within safe margins (I'm using temp probe for measuring chipset temp)
- Power: PSU load do not exceed 35%
- Voltage: the provided original voltage should be enough for my goal, even so I did some tests with slightly rised voltages.
- MB clock generator malfunction: It's working fine on both original 1066 and 1333. Overclocking 1066 to 1333 is impossible and so is OC 1333+
Nov 26, 2005
15,197
403
Anyone else want to jump in on this!?
I am stumped why your memory will not accordingly raise with your fsb ... you should be able to overclock the fsb up to the specified memory speed of DDR3 1800 at specified timings and voltages. Try pulling your cmos and resetting things. And your Bios is up to date right?
exidus
14
Yep, BIOS is up to date, it's even a beta, because older ones doesn't support E0 stepping. With previous processor, BIOS was final version. Tried cmos reset several times also...
Nov 26, 2005
15,197
403
- On a side note question, how are you measuring your PSU load? by a tool?
Set the FSB Strap to 400, rais your fsb to 400 choose DDR3 1600 for your DRAM requency and see if that works.
exidus
14
tried that too :(
I can't rise it to nowhere...
as for the PSU load I'm using separate multimer.
exidus
14
well... corsair didn't felt it's necessary to put more info in their site... only, that it's compatible with this board.
aigomorla
21,126
3,653
if im not mistaken, those ram require more voltage.
Also you want to overclock, you need to learn to play with voltages, so i need to know exactly what voltage you have for everything and what your going after.
The word safe, to a newbie, is virgin to a person whose been overclocking for a while, so our terms are way different.
KingstonU
1,405
16
I would also look more closely at the ram voltage. I was unable to do anything with my computer until I upped the dram voltage to 2.0v like G.Skill's website states as a minimum from the stock 1.8v that bios had it at.
Also I wonder if using the XMP profile has anything to do with it. Can you turn it off and OC everything manually?
exidus
14
ok... so these are max voltage settings i've tried: Vcore up to 1,45V, ram up to 1,80V (it is the extreme1800 profile set, normal is 1,5V), chipset +0.25V - tested and failed @FSB400 & @FSB450
these are my current settings:
Vcore: 1,25V
RAM: 1,5V
everything else is at normal (auto) setting
exidus
14
yeah, I thought about that, but then how come it's working now on 1333 with Q9550 but did not work with the 6600
exidus
14
and yet I couldn't manage to oc to 1333 with the 6600. worked fine on 1066, though
aigomorla
21,126
3,653
Vcore: 1,25V
RAM: 1,5V
E0's dont like high voltage's at all.
Did you try to run at a lower voltage?
I know it sounds funny, but all my E0's were like ladies, they sipped instead of gulped.
exidus
14
I'm aware of E0's voltage issues, so first tested with default voltages.
btw someone on another forum suggested faulty memory controller... I think it's more likely that, than faulty dimms.. still hope it's neither...
aigomorla
21,126
3,653
can i see a picture of your bios screen?
take a camera pic or whatever pic.
The overclocking section is what i need.
Want to see what you set everything at.
VirtualLarry
56,587
10,227
This could be the problem. I've read of other cases in which BETA bioses allowed certain 45nm CPUs to function at stock, but wouldn't OC one iota.
