Here is my motherboard: ASUS A7V KT133
Picture and review of A7V
I had a 800 Mhz T-Bird not OCed in it and it was fine. I recently wanted to upgrade to an Athlon XP 1600+ so I got myself one. The heatsink and fan is a FOP38.
Picture and specs of FOP38
I scraped all of the thermal paste off of the heat sink using rubbing alcohol and a puddy knife. I evenly applied thermal paste (artic silver) using a credit card.
The Problem:
Upon bootup I do not receive a post at all, and I just get a constant beep code. beep beep beep beep.....etc. I turned off the computer immediately to prevent an overheating.
Does this mean the processor is not seated correctly? What would you suggest?
The Problem:
