Problem with new PC
EvilKupo
61
OK, so I've been building computers for the past 15 years and have gotten pretty good at it, which is why this is so frustrating. I'm in the process of upgrading my bro-in-laws computer because he couldn't boot (everytime windows tried to load, he'd get the blue screen) and simply because he wanted to upgrade. So the steps i've taken are as follows....
We bought a new mobo, CPU, PSU, case, and Ram.
Kept the HD at first
Also kept the video card and the DVD drive.
I tried to reformat, kept getting crashes and blue screens.
Finally coming to the conclusion the hard drive is garbage, we got a new one. Windows installed from disk fine, no crashes, no problems. Everything seemed stable.
He gets it home, has a crash. A bit later, he tries to update the windows system rating and gets a blue screen.
After he tried to reboot from the blue screen, there was nothing. The computer turns on but doesn't actually do anything (no start up screens)
I'm so confused on why he's still having problems. I don't think it's the video card, although I could be wrong. I had the video card out and running off the mobo video and still had problems. I know it's possible that the corrupt hard drive could have damaged some of the new parts, but what's the chance of that, and which parts would most likely be the problem?
Any advice would really help. If we need to take the parts back, we only have a few more days and he lives an hour away from me.
Oh and I realize I didn't give any specifics on parts, I didn't think it was needed...but really quickly, he's running a AMD phenom II 1100T, a gigabyte mobo that was recommended by the worker where we got it (yes I should know better than take advice from someone at a store...), 4GB of samsung ddr3 ram, and a Radeon 4850.
DesiPower
15,299
740
I had a similar issues a few months back. My mobo died so I bought a used one from ebay, dirt cheap. Once I installed everything I was having constant BSODs... updated the bios, downloaded latest chipet drivers, tried everything. Since my last mother board died I though one of the existing components might be the culprit. I took all PIC devices out, swapper RAMs, HDDs, PSU but no luck, with even a little bit of CPU load I would get BDOS, it was working fine on idle.
So I decided to take another chance and bought another brand new Intel mobo. Installed everything on it from the original computer, installed OS and tested with all kinds of loads and no problems, everything working fine for about 2 months now!
Moral of the story - is can be the mobo too, people too often ignore it and go for the RAM and PCI devices...
ViRGE
Elite Member, Moderator Emeritus
167
If it isn't POSTing, the problem isn't the hard drive. Strip the computer down to the basics: CPU, mobo, and a stick of RAM. Start with Memtest86 to test the RAM and see what happens.
sandorski
70,881
6,420
So I decided to take another chance and bought another brand new Intel mobo. Installed everything on it from the original computer, installed OS and testes with all kinds of loads and no problems, everything working fine for about 2 months now!
o_Oo_Oo_O
Nov 26, 2005
15,197
403
BSOD? Either something is not getting enough electricity like volts to the ram or somewhere, or the new ram is also bad, like the old set....
mfenn
22,400
www.mfenn.com
:thumbsup:
OP, you didn't mention which mobo you got (it helps to be specific), but if it has onboard graphics, then pull the GPU as well.
