Problem with new Gateway monitor
Navid
5,053
I have got a new FPD2185W LCD monitor from Gateway.
It does not come with a DVI cable. So, I have been using a VGA cable for the last few days.
I ordered this from ebay. I received it today.
When I hook it up and turn on the PC, I get a green screen! Something is obviously wrong.
My graphics card is BFG 6800OC.
What is the problem? Is it the cheap cable?
Navid
5,053
Originally posted by: Throwmeabone
Nice, a $600 monitor with a 99 cent DVI cable. Maybe try a better cable?
Yeah, I know!
I just don't want to get another cable and later find out that the problem is really somewhere else!
Is a dual link cable the right cable to get? Is my graphics card capable of driving this monitor at its native resolution (1680X1050)? Could it be that something is wrong with the monitor? .........
XJustMeX21
1,606
i bought one for 25 at walmart and it works perfectly with that monitor and yes your card is plenty to push that resoultion.
Navid
5,053
Originally posted by: xtknight
Is the DVI cable pushed in all the way on both ends?
Yes it was and I even tightened the two screws on each end. I will try again.
xtknight
12,974
I guess the imbecile on eBay must have sent you one with bad red and blue pins. What a pain...
Navid
5,053
It was the cable!
I got this from RadioSchack and everything looks good.
Now, this is a single-link cable.
When will I need a dual-link one?
For what application will a single-link cable become the bottleneck?
Peter
9,640
You'll need a dual-link cable when your display requires it. Up to 1920x1200, everything is single-link.
