Problem with network config settings
ant80
411
I am trying to help a friend set up an internet connection. They have road runner, and one computer connects to the internet, but the other one doesn't (says there is limited connectivity). I did an ipconfig /release and ipconfig /renew, but the renew didn't work. I thought it might be the built-in network adapter, and installed an old network adapter from linksys that I KNOW works, but I get the same problem. I tried to test the cat5e cable, that is fine as well.
She has a usb wireless card installed, and I know that there are some times when the installation of the USB wireless card changes the configuration on the network, so I went into the configuration>Advanced but there wasn't a property called Link Speed/Duplex, but only a Media Type. I changed that from AutoSense to 100BaseTX_Full Duplex, but it still didn't work.
Is there something I am doing wrong? Or is there anything I am not doing? Does anyone have any idea how I get it to work? I'd greatly appreciate any insight. Thanks.
- ant
JackMDS
29,544
421
In order to avoid theft of signal RR uses that MAC number of the computer that was originally used with the Modem as a form of Authentication.
If the person wants to use more than one computer they have to buy a Cable/DSL Router and build a small private Network.
The Router can be cloned with e original MAC number and keep the connection alive.
See here, http://www.ezlan.net/broadband.html
:sun:
ant80
411
:sun:
G0dD@mn RR for making it so complicated. Thanks JackMDS.
