Problem with my Samsung 712N?
menorton
I recently got a Samsung 712n 17" LCD monitor for xmas (Cost was about $300). My reason for getting this were the good reviews and word about it, specifically b/c what i read about THG about it. The native res is 1280x1024 @ 60 mhz. So i boot it up and it looks all pretty, but to my dismay, it refuses to do 2 things:
1. Acknowledge that any resolution above it even exists and it selectable.
2. Allow me to play at any resolution below the native.
As soon as i try to put it on, for example, 1024x768, the monitor gives me a prompt error saying "Not optimum mode. Recremmended Mode is 1280x1024 60hz". The screen will flash that for a minute then it will go totally black, with just that error floating up and down the screen. So i was like wtf, i thought this was a great monitor, why can't i be in any resolution but native. This is espicially maddening b/c some programs (and older games) only go up to 1024x768, if that. To troubleshoot this, i tried to drop the hz down to 60 at the lower resolutions, but i still got the error
I just called Samsung Tech Help and asked them about my problem. They said that i could only be in my native res and the blacking was with all of the LCDs. In my previous drivers, det 66.23s, they had an option to force the resolution/hz. WHile that was a short fix and i was able to play at lower resolutions, the video was very choppy despite the fact that i was getting 60-100 fps.
So my question is:
1. How can I get the black from appearing and so i can play nicely at any resolution i want?
2. If i can't, what monitor can i buy instead?
System specs:
A64 3500+ (130nm)
PNY 6800GT, dets 71.24
ABit AV8
2x512 Crucial ddr333
winxp
Samsung 712n (Analog input only)
I used to have the same monitor, and it never did this. It has to be a setting somewhere, I had a viewsonic do something similar in the past, and I had to change a setting in the monitors setup menu ( Using the buttons on the front of the monitor, not software). Can you try it on another PC or Laptop ? Have you loaded the Driver CD that came with the scree
n?( most likely not it, but worth a shot ). Try monkeying around in the menu options, I can check my 710T when I get home to see if I can find anything.
