Problem with my Radeon 9500 Pro
CinimoD
Hey guys,
I just received my new Ati Radeon 9500 Pro but had some probs with her. When I go in Display Properties panel I see two things:
1.Plug And Play Monitor on Radeon 9500 Pro / 9700
2. (Default Monitor) On Radeon 9500 Pro / 9700 - Secondary
Then when I check my ATI Display Driver it say this:
Radeon 9500 Pro / 9700 Secondary PCI Secondary
Radeon 9500 Pro / 9700 AGP Primary
PCI?! WTF? Never had any pci video card on this computer. I had a Geforce 2 GTS 32 mb DDR AGP before and removed all Nvidia drivers before installing my new vid card. Also, In Display properties, I don't have the panel to change the antialiasing and stuff. Here's the specifications of my computer:
Athlon 900 mhz
768 mb ram Pc133
Abit KT7 motherboard
don't panic over the secondary PCI thing, the reason might be that computers recognize only one AGP, so the driver trick the computer thinking of the secondary as PCI. AGP is kind of a dedicated accelerated PCI anyway. the important thing is that the secondary driver is installed, but check to make sure by connecting a second monitor to it.
the panel is not there... do you mean the primary or both primary and secondary? if you haven't activated the secondary then probably it won't have the ATI panel. else make sure you install the ATI dislay penel.
