- Dec 25, 2004
- 10,547
- 6
- 81
There's a small problem with my new XFX single-slot HD5770.
The two DVI connectors and the mini-displayport connector are all too close together. When I plugged a mini-displayport cable into the card, I could not plug a DVI cable to the DVI port right next to the mini-displayport. When I had a DVI cable plugged into either DVI port, I could not plug a DVI cable into the DVI plug next to the first one.
All of the ports are too close together. I cannot run three monitors with this card. All I can run at the same time are a monitor off of the mini-displayport and another monitor off of the DVI port on the other side of the DVI port right next to the mini-displayport.
Has anyone seen a DVI cable that doesn't have such a thick plastic housing around the connector?
