- Dec 4, 2004
- 25
- 0
- 0
So I finally got my new system put together yesterday and installed Farcry to see what it could do. I installed everything fine but when I tried to actually play the game it brought up the initial farcry logo then froze. The same thing happened with Call of duty.
When I installed Dark Age of Camelot, which doesn't require a disk when you play, everything worked fine.
While it's trying to load farcry, I noticed the my rosewill combo drive makes a very loud read noise then dies down. Then the comp freezed 20-30 seconds later if I don't cancel it before.
I can listen to music ok from a cd, but it makes a loud noise and takes 5 or 6 second to switch to the next song.
I'm thinking this is my Cd drive's fault but I was just wondering if anyone here had any thoughts on the matter. This is my first build, so a lot of this is all very confusing.
One more thing, my CDdrive was retail but it didn't come with any drivers, and there's nothing on the web site. I think I may try and put it an older cd drive after I get back from work.
Thanks
Mike,
Thanks
Mike,
