Problem with my network
rigmah
Ok, all 3 computers on my network are connected to a hub. I turn them all on but none of them appear in the network neighborhood of the other computers. The hub has all the lights on for each connecton so i know its not the problem with the cable. All of them are logged into the network but arent able to see the other two computers. They were working fine but suddently stopped workin
turn one on and let it stay on for 10 minutes,
turn the next one one and let stay for 10 minutes,
turn last one one and let stay for 10 minutes
try it
try to avoid booting the machines so much until MS networks settles down.
2 of them 98 and one win2k
Ok, i have the two 98 machines seeing each other but the 2000 cant be seen by the other two.
The whole network was working a few days ago then suddenly nothing
K try a few of these options. Do you have a workgroup set up or a domain? First from a command prompt type in "ipconfig /all" (no quotes) That should list the IP of the machine and list the network name. Then after that try pinging the domain or workgroup from a command/dos prompt. Try it by name of PC and IP address. If this is a workgroup make sure the 2000 box is still listed as being part of the workgroup. You might be having a DNS problem with the 2000 box.
