- Jul 20, 2005
- 189
- 0
- 0
Alright, I saw a good deal on NewEgg for some Corsair Value RAM (1GB PC3200 2x512) and bought it without really thinking. It arrived today, and upon installing it, I remembered that my CPU is only 333FSB (AMD Athlon XP 2800+ Barton), so it won't really support PC3200. Then I talked to a few of my friends, one of which said that there was a way to set the PC3200 to be read as PC2700, another saying that if I put my current stick of Kingston 512 ValueRAM in with a 512 stick of the Corsair PC3200, it would be forced to be read as PC2700.
I tried doing what the latter one said, and it worked, however, I'd like to have all 3 sticks of RAM (the Kingston 512 PC2700, the Corsair 2x512 PC3200) in all at the same time. I tried doing this and it got to the motherboard screen (shows the logo of whichever motherboard you have) and froze. It also froze when I had both Corsair sticks in. I tried messing with the BIOS and setting the RAM stuff to 166 (it was at 100) but that didn't really change anything.
I'm in my BIOS right now so I can read off to you what kind of stuff it says or you can ask me to look for something specific in the BIOS that might solve the problem.
Thanks for your time,
Greg
Greg
