Problem with my Lite-On LTR-52327S
lukmeg
567
I have Lite-On LTR-52327S and it does not want to open. When I press the eject button, the light blinks a few times but it doesn't open. Trying to open it via Windows Explorer results in the same thing. It does show up in Device Manager though.
I have tried the following:
-used a different IDE cable
-different power connector
-set jumpers to master, slave and CS
-with and without another IDE device
Do I have a dead burner? Is there anything else I can do to try and fix this?
Thanks for any help.
GregANDTCH
1,370
What kind of disk do you have in it?
Some of the CDRW programs lock the drive when you put a CDRW in there.
What version Windows are you using?
What CD-burning program do you have installed?
lukmeg
567
There is no disk inside and I am using XP, with Nero installed. I think the drive is dead. I've opened it using a paper clip and it doesn't read the disk. Actually it doesn't even spin up. Guess its time to get a new burner.
