- Dec 8, 2004
- 7
- 0
- 0
Help please,
Here is my machine....Athon 64 2800+ W/ Chaintech SK8T800 MB
Chipset VIA K8T800 + VT8237. BFG Nvidia 6800 video card 128 MB ram.
Motherboard and processor less the year old. Updated drivers for video card. Had two sticks crucial 2100 ddr ram but wanted to upgrade. Heard mushkin good product and price was good also.
Ok here is my problem. Tried both pieces ram one at a time and they seem to work fine. When I install both pieces machine becomes unstable.
Programs lock up, monitor flickers. Please help and thank you for your time.
I have a 350 watt PSU. Don't know if its a voltage problem and can't raise ddr voltage that I can find where to do it at thought it would be in here.
Anyway here is a list of the options in my (Frequency/Voltage Control)
1. Auto Detect PCI CLK----Enabled...Only can Enable or Disable
2. Spread Spectrum-----Disabled...Disable or other options are +/-.20%,+/-.25%,etc etc.
3. CPU Clock------200 MHZ Can raise cpu clock from 200 to max of 233.
Don't see anything in there for raising ddr voltage.
Going to run memtest to double check both pieces ram but like I mentioned at top tried both 1 at a time and seemed to work ok.
Any thoughts and thank you for your time.
Terry
Terry
