Problem with MSI6337 and PIII 933
Wallysaurus
454
I just put together a system with the MSI6337 and a Boxed PIII 933MHz CPU. The system seems to run perfectly except for an occasional video freeze. I in stalled MSI's FuzzyII Logic program and found out that my AGP bus is running at 88.7MHz. I have everything in BIOS set to AUTO and have switched to the latest BIOS. I ahve tried changing the over clocking jumper on the board and I have tried changing all the settings that pertain to the memory and cpu clocks. I can't find a setting anywhere that will let me change the divider for the AGP. Fuzzy Logic II says that my memory clock is set at 100MHz whether I leave it on Auto or set it at 100 or 133. It says that the PCI clock is set to 33.3 so at least this is right. Is the 6337 not able to run the 933 cpu or am I missing something some where?
MSI 6337, Boxed PIII 933MHz, 256MB Crucial PC133, IBM 75GXP 45G,IBM ATA66 24G, ATI All-in-Wonder 128,SB Live Value, Diamond Home Free Home Network card, Actiontec Call-waiting modem
woof
38
First thing I would try is not relying on any "auto" settings. The next thing I would do is get a copy of SiSoft Sandra to confirm the speed you're getting from Fuzzy Logic, I don't have a lot of faith in MSI's software.
Good luck.....
Wallysaurus
454
Woof,
I have Sandra 99 Pro installed and it had confirmed what the MSI software had reported. I did, however, download a copy of Sandra 2000 and it reports the AGP to be running at 66MHz. I'm not sure which to believe but I'm leaning towards the latter since I seem to be having zero problems. Do you know of another diagnostic that I could get to double check? BTW, the thread you guys are involved in is what convinced me to buy this board. If I confirm the AGP bus speed, I'm going to see if I can push this thing a little harder. Thanks for your advice.
