thanks again for the help in my last thread
i now have another question: i know that it is best to have all the RAM the same, however, i was wondering if there would be any potential damage if i mix RAM. the modules in question would be the OCZ plat. 8500 and OCZ plat. rev 2 6400. if i was to have both 2gb sets at the same speeds, timings, and voltages, would/should there be a problem? also, is there a risk by underclocking the higher speed RAM to match the lower speed ones? this will only be my setup temporarily, if it works, until i decide to put together the parts for my backup, as at that time i will move the lower speed RAM into that system.
thanks in advance
btw: i know that the 8500s use micron d9s whereas the 6400s use PROMOS ICs...will that pose a problem?
thanks in advance
