Problem with KT7WW flash? Solved
Losty
1,136
I have a problem with the flashing.
The last thing i see after rebooting and changing the settings in the bios is:
Press any key to reboot
This appears after detecting everything (scsi bios, cdrom, burner)right after updating ESCD.
If anyone had the same problem and fixed it or knows how to fix this problem please help me out.
Thanks in advance
Losty
Insane3D
19,446
I believe the new bios has a failsafe that won't let the PC boot if there is not a fan running above 2000RPM connected to the "CPU 1" fan header on the mobo. Plug a fan on to that header and see if it works. Just an idea..
Losty
1,136
Thanks insane3d...
I am aware of the failsafe. It shutsdown the computer.
I get the message : press any key to reboot
I have a fan in header 1.
any other ideas?
Losty
1,136
problem solved.
Caused by adaptec scsi controller.
For anyone who runs into this problem, I read from kt7faq that disabling scsi cdrom bootup fixes the problem.
